Full Version: No Controls on Fullscreen Live TV // Kodi 18 Laia RC1
If i watch Live TV Fullscreen and i press Ok i should be able to move the current control in the menu down there. that won't work anymore Smile i think this is skin related.
if i am on fullscreen video it works.
i made a video to make it clear.
https://youtu.be/g9NBG9bGHaM
Hi skybird.
Thanks for reporting the issue.
I totally see what you mean.
Try using this file in your skin.rapier/720p folder:
https://www.dropbox.com/s/q4kkyyghzensl0...D.xml?dl=0
It should fix the issue and focus the stop button if the play button is not visible.
hi gade, i think there goes something wrong  Smile)
https://abload.de/img/screenshot004swdqm.png
Exit Kodi.
Copy VideoOSD.xml from the link above to your skin.rapier/720p folder and overwrite the existing one.
Start Kodi.
Your image has nothing at all to do with the current fixes I did.
Gade, please check the video if i did something wrong. Smile
https://youtu.be/_CCKH5YOGyA
Ah, I know why.
It's part of some scaling fixes I did.
You need the includes.xml file as well. :-)
https://www.dropbox.com/s/f6kkkpjev6x6ah...s.xml?dl=0
Please let me know if the issues are fixed.
I updated the skin in my development repo, so everything should be working correctly for you shortly.
Repo Version now works. Didn't see your last post before. Smile thanks 4 fixing.
Thanks, great that it's working.
Thread marked as solved.
