2018-11-26, 18:16
I want to buy or build a Linux system for Kodi that can do 4k playback with no issue and can also support HDR. My Question is, is this even possible or am I chasing a unicorn?
Thanks, UbuntuUser
Thanks, UbuntuUser
(2018-11-26, 18:16)UbuntuUser Wrote: [ -> ]I want to buy or build a Linux system for Kodi that can do 4k playback with no issue and can also support HDR. My Question is, is this even possible or am I chasing a unicorn?I am not sure about HDR, but my AMD Ryzen 2400G plays 4k 10 bit HEVC without issue. I am dual booted with Kubuntu and Libreelec and both work great.
Thanks, UbuntuUser
(2018-11-26, 21:37)wsnipex Wrote: [ -> ]there is currently no way to output 10 bit and HDR metadata on linux(mesa and/or kernel issue, which is being worked on by intel).Is this done automatically or is is something you have to setup?
Kodi 18 has tonemapping support, which allows us to play 4K HDR and output adjusted colors as SDR.
(2018-11-26, 21:37)wsnipex Wrote: [ -> ]there is currently no way to output 10 bit and HDR metadata on linux(mesa and/or kernel issue, which is being worked on by intel).Is this just for Intel GPUs - or does it also apply to AMD and nVidia? (You mention Intel working on the mesa/kernal issue?)
(2018-11-27, 01:47)UbuntuUser Wrote: [ -> ] Is this done automatically or is is something you have to setup?tonemapping is done automatically, but you can adjust it.
noggin Wrote:Is this just for Intel GPUs - or does it also apply to AMD and nVidia? (You mention Intel working on the mesa/kernal issue?)afaik, it's done for intel atm, but I'd expect AMD to implement it eventually as well.
(2018-11-27, 14:14)wsnipex Wrote: [ -> ]noggin Wrote:Is this just for Intel GPUs - or does it also apply to AMD and nVidia? (You mention Intel working on the mesa/kernal issue?)afaik, it's done for intel atm, but I'd expect AMD to implement it eventually as well.
Nvidia always does it's own thing and should be avoided for kodi, specially with v19, where we'll drop vdpau support(deprecated and not supported by nvidia anymore)
