I have several split video files. They scrape correctly and "information" shows they have stacked correctly for playing but they don't. Each part will play fine but when trying to play the stack, only the first part plays.
The log is at
https://paste.kodi.tv/sawujorano
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Thanks for pointing out those bogus repositories. I removed them and checked that nothing was installed from them. I believe everything is clean now. Thanks again.
The new log is
https://paste.kodi.tv/iwuzefosak.
I have tried stacking MP4s and they work fine but ISOs error out and abort, Any suggestions?
I couldn't see anything in the log as Debug Mode was not enabled.
But if your problem is with ISO's, then I am pretty sure you cannot stack ISO"s. But I don't use them so others may have to confirm.
I suspect you are right about stacked ISOs not working. Don't recall seeing that in documentation but experimental evidence points in that direction. Guess I have a conversion job ahead of me.
