Hi all,
With the latest version of Studio Icons - Coloured 0.0.11 the icons aren't showing up. All links to resource://resource.images.studios.coloured are empty.
Can someone look into this I tried but don't know how to solve this.
Thank you!
thanx for the report!
the issue will be fixed in 0.0.12
Hi Ronie,
Thanks for the update, but the icons are still not showing in Aeon Nox 5: SiLVO and it's telling me that the ''Direct texture file loading failed''.
If you need something from my side like a log, please let me know.
v0.0.13 will fix the issue... for real this time ;-)
It's fixed you my friend are amazing, keep up the amazing work!!!
ronie
Kodi v17.6 on Win 10
I am having a problem with the add-on failing to update to v0.0.13. Let me know if you need the whole log.
xml:
11:24:20.131 T:388 ERROR: Failed to rename file/directory \\?\C:\Users\HTPC\AppData\Roaming\Kodi\addons\resource.images.studios.coloured to \\?\C:\Users\HTPC\AppData\Roaming\Kodi\addons\temp\05604ee8-628d-43d8-8fc9-9e15632765bb, Error:
11:24:20.131 T:388 ERROR: XFILE::CFile::Rename - Error renaming file C:\Users\HTPC\AppData\Roaming\Kodi\addons\resource.images.studios.coloured
11:24:20.131 T:388 ERROR: Failed to move old addon files from 'C:\Users\HTPC\AppData\Roaming\Kodi\addons\resource.images.studios.coloured' to 'C:\Users\HTPC\AppData\Roaming\Kodi\addons\temp\05604ee8-628d-43d8-8fc9-9e15632765bb', retrying in 500ms
11:24:20.634 T:388 ERROR: Failed to rename file/directory \\?\C:\Users\HTPC\AppData\Roaming\Kodi\addons\resource.images.studios.coloured to \\?\C:\Users\HTPC\AppData\Roaming\Kodi\addons\temp\05604ee8-628d-43d8-8fc9-9e15632765bb, Error:
11:24:20.634 T:388 ERROR: XFILE::CFile::Rename - Error renaming file C:\Users\HTPC\AppData\Roaming\Kodi\addons\resource.images.studios.coloured
11:24:20.634 T:388 ERROR: Failed to move old addon files from 'C:\Users\HTPC\AppData\Roaming\Kodi\addons\resource.images.studios.coloured' to 'C:\Users\HTPC\AppData\Roaming\Kodi\addons\temp\05604ee8-628d-43d8-8fc9-9e15632765bb', retrying in 500ms
It is strange though as the add-on shows the installed version is v0.0.13, and it is trying to update itself to v0.0.13
Any ideas?
nope, sorry i don't have any idea.
you could check if the C:\Users\HTPC\AppData\Roaming\Kodi\addons\temp\
directory exists, is empty and writable.
also, double check what version is actually installed, by looking inside C:\Users\HTPC\AppData\Roaming\Kodi\addons\resource.images.studios.coloured\addon.xml
My fault. Now that I look in the add-ons folder, I remembered I had modified the xbt file and saved a few versions in the addons folder. I am guessing that is the cause of the fail.
Is this hosted on Github or Gitlab so I can submit some icons?
The icon fro DreamWorks has all but disappeared instead I see some colors.
was able to reproduce. this issue will be fixed in the next version of this addon.
