Hi All, I'm using the nightlies downloads : Kodi v18 "Leia" nightly for Kodi - 64bit. The last few downloads have changed my movie results. I'm seeing a lot of Bollywood movies.
How do I remove these movies? What setting will remove any foreign from my view? Is it a repository that I should remove? Is there a setting?
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
