Full Version: [WINDOWS] HOW-TO get Sony PS3 Bluetooth Remote Control working using EventGhost
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
Yup was deffo the remote sleep causing the probs, still not had to re pair. Might be worth looking into whomever is maintaining that app.
Any more news on this?
Hi Guys,
Been using the Official XBMC remote for Android over wifi fine - just got myself a PS3 remote for my GF when my and my phone are out!
Trying to set up up EventGhost (which I have used ages ago) - looking at the youtube tuts, it shows EG capturing events from the remote when you push a btn on the PS3 remote - which you then drag and drop to events - easy enough.
However, I've only ever seen my remote seeimgly send anything to EG - somthing along the lines of HID.Hibernate.Disabled.
To me, this would suggest the remote cant exit hibernate mode?
Few points:
1. Succesfully paired in Win7
2. Latest version of EG (0.4 etc from site)
3. Got the PS3 Remote plugin from EG (the one in the plugin list)
4.Installed "XBMC2" plugin
Quite apart from getting Doggs XML to work (which just threw up a load of red errmsgs when I tried to open it in EG) - this looks pretty simple once I can get it to receive anything from the PS3 Remote...
Prob something simple - as I say , just a push to get me started would be great! Smile
THX
Hi guys,
Pretty stuck here - not even entirely certain the PS3 remote I bought isnt duff (tho Win 7 does connect to it)
Full err log below - the arg I was looking for last night is KeyError."Hid:Wake"...
Any help? Thanks! Smile
System.DeviceAttached [u'\\\\?\\HID#{00001124-0000-1000-8000-00805f9b34fb}_VID&0002054c_PID&0306#8&2827bff3&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}']
Unhandled exception in WorkerThread <ActionThread>:
Callers stack:
File "threading.pyc", line 504, in __bootstrap
File "threading.pyc", line 532, in __bootstrap_inner
File "threading.pyc", line 484, in run
File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 354, in __MainLoop
self.__DoOneEvent()
File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 328, in __DoOneEvent
action.PrintUnhandledException()
File "C:\Program Files\EventGhost\eg\Classes\ActionThread.py", line 92, in HandleAction
pluginInfo.treeItem.Refresh()
File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 69, in __call__
self.processed.set()
File "C:\Program Files\EventGhost\eg\Classes\EventGhostEvent.py", line 178, in Execute
eg.SetProcessingState(1, self)
File "C:\Program Files\EventGhost\plugins\PS3\__init__.py", line 1220, in handle_device_attached
eg.actionThread.Call(instance.__start__, *instance.args)
Traceback (most recent call last) (1568):
File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 326, in __DoOneEvent
self.HandleAction(action)
File "C:\Program Files\EventGhost\eg\Classes\ActionThread.py", line 87, in HandleAction
action()
File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 62, in __call__
self.returnValue = self.func(*self.args, **self.kwargs)
File "C:\Program Files\EventGhost\plugins\PS3\__init__.py", line 1316, in __stop__
eg.Unbind('HID.Wake', handle_wake_up)
File "C:\Program Files\EventGhost\eg\Core.py", line 191, in Unbind
eg.notificationHandlers[notification].listeners.remove(listener)
KeyError: 'HID.Wake'
It is not possible for us to convert the file format from XML to any other it is showing error when i save the file with XML extension.??
forklift seat
