Full Version: HTTPS is not work within Kodi 18
HI
Can someone pease have a look at why the HTTPS is not with in Kodi 18 i have my own servers and this work ok with in Kodi 17
so for e.g. https://kodi.tv/tv << this not working when you go in to add file and so on
give it a go number of ways
1. install 17 and put 18 over the top ( the https work in 17 but didn't in 18 )
2 install kodi 18 clean << didn't work
work love to give Kodi 18 but can't with out this
thank you
see https://forum.kodi.tv/showthread.php?tid...pid2737320
and the whole thread for reference
Hi
I've been posting this for months now and no one has got back to me about this when you had add a drive over the network by https on kodi 18 and upwards you can't watch the program.
So for example go to video file add file again https when the window shows up go to https ess-login at the drive when kodi does it update it will show up with the program the but you can't play it can somebody test this out please it needs fixing thank you
If you need more information about it please let me know thanks
@PNO1
I have merged your new thread into your original thread, and removed your 3rd thread as we don't allow duplicates.
You did not respond to @wsnipex, so while it is true that you have been posting for months, it is false to state nobody has helped you when clearly you have been pointed to a relevant thread which I assume holds your answers.
Also a Debug Log is always needed, which you have not provided.
