Full Version: kodi addon dvblogic
Hello,
While the support for win7/wmc is ending, i am in the process of transferring to win10/kodi.
after a lot of trail and error i got most working.
but i have still some troubles/questions
- how do i change the recording location? (it should go on the second drive, the first is only a small SSD)
- all channel and epg entrys are messed up! (npo1 wit epg from ngc, rtlz with epg from disney channel and so on)
- if i change the serversoftware to tv mosaic, will this be the same addon?
rgrds
Henk
Hello,
- you can change recording location in setup-settings-recorder tab
- you could try and ‘clear data’ in kodi-settings-livetv-general and guide. Sometimes clearing cache is also needed
- yes
Regards,
Atreyu
thanks
Henk
