Full Version: v18 - nVidia Shield - DVD ISO playback problem with Leia
Pages: 1 2
I'm using Kodi on my nVidia Shield TV (2015).
Video files are streamed from my NAS thru NFS.
With some DVD ISOs (Star Trek DS9 and Star Trek Voyager DVDs for example), using beta versions of Leia (up until nightly of November 28th), the picture isn't completely smooth. There's a small "jump" ("stuttering" ?) approximately 2-3 times/sec. It's there constantly from beginning to the end of the file.
Since December 2nd nigthly (kodi-20181202-812855d8-master-arm64-v8a.apk), it's worse and practically unreadable : the image is freezing almost completely (but audio is ok), stepping forward every 5-10 seconds. Not really playing, just showing an image for 5-10 seconds will the sound is playing fine, then going forward to another one, etc.
Blu-ray ISOs and other video files are fine.
The stuttering problem wasn't there on Kodi v.17 and on Kodi V.18 alpha.
It appeared on beta versions of v.18 (beta 3 I think, but I'm not sure about that...)
The "unreadable" problem wasn't there before December 2nd nightly and is still there on the official RC.
Any thoughts ?
Here's some more details and examples.
My setup:
nVidia Shield TV -> Pioneer AV receiver -> LG OLED UHD TV
I've recorded three examples of the same video (Star Trek DS9) with three versions of Kodi (I know, the colors are off and the image is not centered... But that's not the point).
You'll see that the problems I've mentioned are present only with the episode, not with the DVD menu animations.
That tells me that those problems are probably due to some deinterlacing detection mistakes.
For each example :
  • I uninstalled Kodi from my nVidia Shield;
  • Install another version of KODI by downloading the files from https://mirrors.kodi.tv/releases/android/arm64-v8a/
    and put them in the "Download" folder of the Shield;
  • Changed six things in the Settings menu (everything else is by default) :
    • System/Display : Delay after change of refresh rate -> 2.5 seconds
    • System/Display : Set GUI resolution limit -> Unlimited
    • System/Audio : Number of channels -> 7.1
    • System/Audio : Allow passthrough -> On (and all the other passthrough options under that to "On")
    • Player/Videos : Adjust display refresh rate -> On start / stop
    • Player/Videos : Processing : Allow hardware acceleration - MediaCodec (Surface) -> Off
(Yes, I tried to populate the whitelist, but it didn't change anything)
Here's the video with v18 RC2 (unreadable) :
https://drive.google.com/open?id=1SLQ-sh...y8hnBbwpBU
Here it is with v18 RC1 (readable but small stuttering. That problem is mostly apparent on long movements, see the opening sequence at 0:20) :
https://drive.google.com/open?id=1Omid2I...hE1TLHM9RJ-
And with v18 Beta 1 (readable, no stuttering and deinterlace mode not automatic) :
https://drive.google.com/open?id=1P41sUQ...PwLJpYutc6
Oh! I forgot: it's not me that makes the video infos appearing and disappearing in the RC2 example. It's doing that all by itself...
I checked again today with v18RC2and the problem of video not playing is there for any DVD ISO, not just TV shows.
Here's the log:
https://paste.kodi.tv/vosewejixu
I opened a issue on GitHub:
15005 (GH issue)
Same problem here but it was ok on the rc2 nightly from 26 or 27 november, i don't really remember the day precisly.
Today i installed the latest nightly and i got the same issue.
(2018-12-07, 08:19)AlleV8 Wrote: [ -> ]Same problem here but it was ok on the rc2 nightly from 26 or 27 november, i don't really remember the day precisly.
Yes, you're right. The problem seems to be starting after November 27th.
Last night, I tried directly with a small .VOB file that I've extracted from a DVD and put in a local folder of the nVidia Shield.
The problem is the same. I really think it's a deinterlacing problem.
Link to that file : https://drive.google.com/open?id=1Asw7xY...tU-VTFirIA
Update:
I've made more testing this morning and I can confirm that the issue was introduced in the November 28th nightly (kodi-20181128-5880ccf2-master-arm64-v8a.apk).
The video file is playing fine on November 27th nightly (kodi-20181127-93086fd8-master-arm64-v8a.apk).
Hey Frodonf, have you made further test with the latest nightly? The issue still persist?
(2018-12-14, 20:25)AlleV8 Wrote: [ -> ]Hey Frodonf, have you made further test with the latest nightly? The issue still persist?
Hi AlleV8,
 Tried it yesterday with kodi-20181212-0665f066-master-arm64-v8a.apk.
Same issue.
Have you installed the latest shield experience update? Probably it doesn't make any difference, but you'll never know...
Because i read so many complaints I'm afraid to update my shield, but you know, every update it's the same story.
At least in the oreo update, they finally solved the stuttering issue with 25fps on 50hz refresh rate.
(2018-12-14, 21:33)AlleV8 Wrote: [ -> ]Have you installed the latest shield experience update? Probably it doesn't make any difference, but you'll never know...
Yes I did that too and it didn't solve the problem.
All I got is a new HDMI handshake problem between my Shield and my Pioneer AV receiver.
When powering on everything (using an Harmony remote) I have to switch the receiver source to another one and back to the Shield's to have a correct image.
 You're right about the 25 fps issue.
Here's a small update :
Still unable to read video correctly after a factory reset of the Shield and a clean install of the latest Kodi nightly (kodi-20181214-4c17e776-master-arm64-v8a.apk).
I just installed Kodi, installed Kodi Log Uploader and play the video file (stored on the "Movies" folder of the Shield internal memory).
The video file used is there: https://drive.google.com/open?id=1CqILOH..._jUlSW7RpT
The log file is there: https://paste.kodi.tv/nevayahoye
(2018-12-15, 18:07)Frodonf Wrote: [ -> ]Here's a small update :
 Please try the apk which can be found here: https://jenkins.kodi.tv/job/Android-ARM64/8501/
(2018-12-17, 13:31)peak3d Wrote: [ -> ]
Hi peak3d,
Thanks a lot. The two problems are completely resolved with that.
I can read the video file and the image don’t stutter at all.
But there’s a small glitch and a big problem:
The small glitch appears when starting the video file (low resolution files like DVD iso, no problem with Blu-ray ISO/mkv/mp4): image/sound freezes then goes to black, then sound gets back, then images gets back after two or three seconds.
After that, all is smooth and fine.
The big problem is a bug that I didn't see before:
1. Start a 25fps movie (DVD iso of a zone 2 pal DVD streamed from my NAS thru NFS)
2. Stop the movie
3. Start the .vob file I used for testing (on local drive of my Shield)
After a second or two, the Shield reboots all by itself (the nVidia logo appears, etc.).
I tried to reproduce that bug with the November 27th nightly and it’s not present.
Then I completely removed Kodi from my Shield, reinstalled it with the file you provided me and reproduced the reboot bug.
Later today, I’ll try to reproduce it with two small files on the Shield’s local drive and create a log file for both releases.
Update:
Finally, I wasn't able to reproduce the reboot bug, even with your build.
Maybe something to do with installing the apk you provide over another build.
Anyway, after a clean install, everything looks good (apart for the little glitch).
Here's a log file for the glitch part:
https://paste.kodi.tv/kipayofuma
Thanks again!
Pages: 1 2
