Full Version: "Search episode" suddenly not working anymore?
usually TMM never finds the episode using themoviedb without a manual search, so i click "Search episode" and choose the correct result.
However suddenly it does not return any results with any information provider - even for episodes that have already been scraped.
I have this in the error log:
Quote:16:17:13.242 WARN  org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_fanarttv.conf' - using defaults
16:17:13.258 WARN  org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_imdb.conf' - using defaults
16:17:13.274 WARN  org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_moviemeter.conf' - using defaults
16:17:13.289 WARN  org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_omdbapi.conf' - using defaults
16:17:13.430 WARN  org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_opensubtitles.conf' - using defaults
16:17:13.461 WARN  org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_tvdb.conf' - using defaults
Somehow related? Any way to fix this?
unfortunately this does not help, look for a block starting with "getting metadata" and look if there are any errors.
Be sure, that your TV show has all needed IDs for scraping!
This is all there is in the error log.
The IDs are set, the show was scarped before. It only happend now when a new episode was aired.
