Full Version: Unable to play series from NFS link.
=11ptHi All,
I have a problem playing series that are added to the main screen from a NFS share. I have a gut feeling it is due  to the newly added harddrives.
Facts:
Playing movies on the main screen added from the same NFS share works..
If i add the same folder through a SMB link it works playing from the start screen.
If if go to filebrowser, select the NFS share and try to play the same episode from a serie it will also play.
The issue is what it wont play the file if i select it from the main start screen and it is indexed from the NFS link.
It used to work before. Since i swapped out my HDDs on my Synology NAS and reinstalled the system + reconfigured from scratch have these issues.
Specs:
Kodi running on LibreELEC (Leia) v8.90.008 ALPHA (Kodi 18 RC 1)(same issue on Libreelec 8.2.5 Stable). Running Kodi v17.6 Krypton.
=11ptStorage pool 1, filesystem is BTRFS configured as RAID  1. 2x 10TB HGSTE HE10 HUH721010ALN600 drives.=11ptNAS is a Synology DS918+ + Storage Pool 1.
Anyone came across this before?
