Full Version: Kodi is crashing and screen flickering in full screen
I'm using kodi on windows. as soon as I start kodi the screen starts flickering and almost like snow from no channel on a tv, also the time will flash at the bottom right when it does it. When ever I try and play a video kodi crashes. I've tried a few things I found searching online. Turn off acceleration, Reinstall kodi, and update video driver. I've found that when I change to window mode it stops doing it. I'm trying to run it at the default setting and resolution which is 1080p on my laptop. Its a 2018 laptop with gtx 1070. Anyways I'm completely lost Never seen this before. Kodi as always worked good on anything I've put it on except this new laptop.
strike that, it does it in window mode as well now
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
...  Well this is embarrassing and I have to be the dumbest person ever. So I just bought this laptop, came in the mail today. Its the asus Zephyrus's M. I totally pulled it out of the box put kodi on it and was having these issues. I started messing around with the ROG settings and realize the PC was set on Intel intergraded graphics. There is a setting to switch between Intergraded and GPU for Battery saving. Funny thing is I didn't realize how good the intergraded graphics are these days. I fired up one AAA 2017 title and was still getting like 90 fps from it. I just assumed the damn laptop came out of the box with GPU on.
 Still kinda weird though that kodi would work on the intergraded graphics. If anyone is interested I can still post the debug log.
(2018-12-08, 07:59)k131n Wrote: [ -> ]If anyone is interested I can still post the debug log.
Since we still don't have a crystal ball in our midst, I'd say yes.
Enable debugging, RESTART Kodi, reproduce the error(s), stop Kodi, and provide the debug log (wiki).
