Full Version: Apple TV 1g changes video output when KODI is loaded
Hello,
Hopefully someone can help me out on this. My Apple TV 1g worked fine with KODI, but suddenly it "crashed". I can not use the menu after 2 seconds, both my monitor and tv are giving messages that the video output is out of range. My monitor says the following:
Input signal out of range!
h = 33.8kHz, V = 30Hz.
Change mode to 1920 x 1080 60Hz.
This is weird because when booting KODI it works perfectly fine os 1920x1080, and I can even use the menu for a few seconds before it shuts down. It keeps resetting itself it with the same message. I can not use the menu interface longer than a few seconds, so going through settings is not an option. Any thoughts on this?
Regards.
