2018-12-09, 14:01
Hi !
After my previous Mac Mini out of order due to a hardware defect i set up a new system.
Before exchange i had Kodi v17.6, with MySQL server. My movies and concerts are stored on a Synology NAS. My series are stored on my VU+ Ultimo 4k sat receiver, and my music was stored on a 128 USB stick directly on the Mac mini (because of small SSD).
This system worked since 2012 (i think) and i was more than satisfied with this.
But now i can't get it running:
3rd time is setup the system:
1. New install go everything on 1tb HDD. System was to slow for me ;-) And first problems with installation of mysql. Later it was running, everything was imported, but no new content were scraped. Tried 17.6 and 18RC2
2. Exchanged the 1tb HDD with 500gb SSD: New Mojave installation, wanted to start with clean MySQL installation, but a lot of problems when i tried to enter the password. Tried different version of SQL, different scripts an tutorials. Later the SQL Server was starting and stopping aso (used the home-brew way). Tried 17.6 and 18RC2
3. New try (this one): Clean Mojave with clean MySQL installation (latest version 8.0.13) and directly started with Kodi v18RC2. After a lot of tricky problems eg my.cnf made a lot of trouble to the SQL server (start/stop) a read that with the new version the cif isn't necessary. Deleted it ... adding of my media sources was possible. Everything i have previously exported with info files is imported. A lot of stuff is in.
But my problem now is:
It's not possible to scrape new stuff:
- Series is not working. Tried it on 2 different folders. One on Synology and one on the VU+
- Movies i try later, i need a new test file for it.
- Music is stored now directly in the music folder of the Mac Mini: Importing is possible, also update of new content is working.
I have the same advancedsettings.xml; passwords.xml; sources.xml; favorites.xml; wakeonlan.xml; upnp-server.xml. I tried different scrapers but nothing happens.
When i update with Mediaelch, Kodi will add later the new files.
Any hints ? What i'm doing wrong ? What is missed ?
I have no clue any more ... :-(
Logfile: https://paste.kodi.tv/galexepusa
