Full Version: Adding additional menu with content display
Hello,
I am having issue with displayed content in my additional menu not redirecting to the addon when it is clicked. Currently, all items are displayed but there is no click action.
The onclick for this panel is showing
 <onclick>$INFO[ListItem.FileNameAndPath]</onclick>
which I'm assuming is incorrect. The addon is a program type. Thanks in advance for your assistance
<control type="group" id="80000">
                    <include>imagefade</include>
                    <visible>String.IsEqual(Container(9000).ListItem.Property(id),user_interface)</visible>
                    <include content="Visible_Right_Delayed">
                        <param name="id" value="user_interface"/>
                    </include>
                    <control type="panel" id="80100">
                        <left>65</left>
                        <top>80</top>
                        <right>0</right>
                        <bottom>0</bottom>
                        <onup>9000</onup>
                        <onright>9000</onright>
                        <onup>14100</onup>
                        <ondown>14100</ondown>
                        <preloaditems>2</preloaditems>
                        <scrolltime tween="cubic" easing="out">500</scrolltime>
                        <orientation>vertical</orientation>
                        <!--<visible>Integer.IsGreater(Container(70100).NumItems,0) | Container(70100).IsUpdating</visible>-->
                        <itemlayout width="330" height="396">
                            <control type="group">
                                <top>130</top>
                                <include content="InfoWallMusicLayout">
                                    <param name="fallback_image" value="DefaultFavourites.png" />
                                    <param name="focused" value="false" />
                                </include>
                            </control>
                        </itemlayout>
                        <focusedlayout width="330" height="396">
                                <depth>DepthContentPopout</depth>
                                <top>130</top>
                                <animation effect="zoom" start="100" end="110" time="200" tween="sine" easing="inout" center="170,320">Focus</animation>
                                <animation effect="zoom" start="110" end="100" time="200" tween="sine" easing="inout" center="170,320">UnFocus</animation>
                                    <param name="focused" value="true" />
                                </include>
                            </control>
                        </focusedlayout>
                            <content>plugin://plugin.program.userinterface/?mode=builds</content>
                    </control>
you would need to know the plugin
<onclick>ActivateWindow(plugin)</onclick> not done any with plugin but have added extra menus https://forum.kodi.tv/showthread.php?tid=333279
it would be like a menu item
 <item>
 <label>$LOCALIZE[3]</label>
 <onclick>ActivateWindow(Videos,root)</onclick>
       <property name="menu_id">$NUMBER[11000]</property>
 <thumb>icons/sidemenu/videos.png</thumb>
       <property name="id">video</property>
       <visible>!Skin.HasSetting(HomeMenuNoVideosButton)</visible>
      </item>
(2018-12-12, 05:29)the_other_guy Wrote: [ -> ]you would need to know the plugin
 <item>
      </item>
Thank you for the suggestion. I will try replacing
with the window id info generated from favorites. I will let know how it goes.
 <item>
      </item>
 Hello,
Unfortunately, it did not work as expected. Clicking on any of the content takes me into the plugin, it does not play the content. Anything else I can try?
your most likely copying wrong part of the line in favs, Pm me the text if you like.
