a message say "missing inputstream.adaptive in your KODI install".
Where can find an install tutorial for this videoplayer inputsream addon?
I'm new with KODI.
WIN10 on PC ACER PREDATOR HELIOS 300
TY for help by advance
It can be installed from the Kodi repository. Go to...
Add-ons > Box Icon top left of the screen > Install from repository > VideoPlayer InputStream > InputStream Adaptive
Which version of Kodi are you running?
For up to date versions, you should find it in the official repo (the built-in one).
First from the main menu go Addons > My Add-ons > Videoplayer InputStream and if it's there select InputStream Adaptive and check it's enabled.
If it's not installed, go to Addons > Install from repository > Kodi Add-on repository (you may not need this step if you have no other repo's installed) > VideoPlayer InputStream and install it from there.
(2018-12-13, 11:08)Karellen Wrote: [ -> ]It can be installed from the Kodi repository. Go to...
also get this error
I trying updating/reinstalling the addon but get an error messag
"the dependency on kodi.binary.global.main...."
how to fix this?
What is the purpose of this addon
and what addons or function needs this?
(2019-02-14, 09:11)madmax2 Wrote: [ -> ] (2018-12-13, 11:08)Karellen Wrote: [ -> ]It can be installed from the Kodi repository. Go to...
also get this error
how to fix this?
Make sure you are using the up to date stable Kodi 18. If you try to install the latest inputstream.adaptive version on pre-release Kodi 18 rc or beta you will get that error.
(2019-02-14, 13:02)arvvoid Wrote: [ -> ] (2019-02-14, 09:11)madmax2 Wrote: [ -> ] (2018-12-13, 11:08)Karellen Wrote: [ -> ]It can be installed from the Kodi repository. Go to...
also get this error
how to fix this?
thanks
was on kodi v18 rc5..
it installed after I
-upgraded to kodi 18
-upgraded to kodi 18.1 RC1
what is purpose of this addon?
which addon needs this?
(2019-02-15, 01:18)madmax2 Wrote: [ -> ] (2019-02-14, 13:02)arvvoid Wrote: [ -> ] (2019-02-14, 09:11)madmax2 Wrote: [ -> ] also get this error
how to fix this?
It's a client for adaptive streams and can play DRM content using an external library like Widevine.
A lot of different add-ons relly on inputstream.adaptive for playback. (example: Youtube, Netflix, Amazon, Hbo Go, ecc...ecc...ecc... )
Hi All
Running kodi 18.4 on osmc vero box 4K.
My inputstream addon is stuck at 2.3.22 and it will never update, even though there are newer versions. I tried to use
https://github.com/peak3d/inputstream.ad...master.zip as the repository to install but that gave errors and wouldn't install the repository.
How do I install the latest version and get it to update itself when necessary?
I'm not very learned up on linux but will be able to follow commands from the ssh.
First thing to try is updating the repo itself. Navigate to it in the addon browser (My Addons > Addon Repository , open the context menu for the Kodi menu and select information adn then update). If there's any update there then do it and try again with the update for inputstream.adaptive.
floatingkiwi Inputstream.adaptive 2.3.22 is the latest stable version available. So for stable everyday use, that's the version that should be used. Inputstream.adaptive is a binary add-on written in c++ witch means, it has to be built/compiled for the specific platform you are going to use it on.
By downloading the master.zip from GitHub you simply downloaded the current source code, to use it, you would need to build/compile it yourself for your specific platform.
Inputstream.adaptive is available through the Kodi official repository, and on various Linux distributions through the repositories of the os maintainers, so you don't have to worry about it, it will get auto-updated as soon a new version for your system is available.
(2019-11-01, 14:21)arvvoid Wrote: [ -> ]@floatingkiwi Inputstream.adaptive 2.3.22 is the latest stable version available. So for stable everyday use, that's the version that should be used. Inputstream.adaptive is a binary add-on written in c++ witch means, it has to be built/compiled for the specific platform you are going to use it on.
excellent thank you!!
Hi
I am running Kodi 17.8 : can not find the Input Stream adaptive here.....what am I doing wrong?
(2019-11-07, 17:01)[email protected] Wrote: [ -> ]I am running Kodi 17.8 : can not find the Input Stream adaptive here.....what am I doing wrong?
You mean Kodi v17.6, there is no v17.8
Those instructions are for v18. Try updating to v18
(2018-12-13, 10:52)Unknow28 Wrote: [ -> ]Hi,
I'm new with KODI.
bash:
sudo apt-get install kodi-inputstream-adaptive
Installed inpoutstream, kodi19. The YouTube-Mpeg Dash section was activated . When playing video clips of good quality for some reason is offered in the standard-mpd, this file does not play the Kodi player for some reason ? It is not clear why the choice is not offered for MP4. 2080p-4k ? Problem with the mpd format.
