Full Version: Button in order to close the lyrics?
I wonder if there's a possibility to add a button to close the lyrics or otherwise what instruction i need to give in order to terminate the lyrics window?
i mean, for now the button stop will close the music player, obviously, i want just to get out from the lyrics window without closing or stopping the music.
A normal close button o what instruction i need to put inside the code in order to switch the stop button with a normal exit.
Tried with "Close" but nothing append.
there already is a close button on the lyrics dialog, just click on the icon twice and the window closes.
also the usual 'back' and 'esc' buttons on a keyboard/remote will work.
you may need to hit those buttons twice in case the music osd is also visible.
(2018-12-14, 17:33)ronie Wrote: [ -> ]there already is a close button on the lyrics dialog, just click on the icon twice and the window closes.
Thank You Ronie!
so Kodi logo for twice time!
Does actually exist a way to access the kodi logo button with a remote also? (like for example "right" twice in order to highlight it and select it or it's only possible by a mouse?)
that one works only with a mouse
