Hi, I have a problem with my IPTV Simple Client on a Raspberry PI.
2 days ago, I have a power faillure. Since this time, the add-on PVR IPTV Simple Client doesn't start anymore, when I start Raspberry PI.
On the start page, the TV menu is not available anymore. I don't see it anywhere.
I remove it 2 times, an install it twice. Nothing change.
I try to install another add-on, but each time, I can't download the package... but I can download PVR IPTV Simple Client.
I don't know how to refix it.
Thank a lot for your help.
Same problem was with me but now its clear
I have the same problem on my Macbook pro. The PVR is not starting and channels are not loading. Hope somebody has a solution!
Same here. In debug I see:
Dont want to broadcastmy iptv subscription credentials, so pasting the portion of the logs.
the file is not missing, I use the same link on my pc and phone. I also re-entered this link couple of times but still same issue.
In case you need the debug file I can send you privately.
I have the same problem with both of my PIs - Kodis.
Thanks in advance!
22:57:59.009 T:1682010880 ERROR: CCurlFile::Open failed with code 404 for
http://vippro.wezzy.pro:8888/get.php?use...&output=ts
22:57:59.009 T:1682010880 ERROR: Open - failed to open source <http://vippro.wezzy.pro:8888/get.php?username=pro352&password=SCRAMBLED&type=m3u_plus&output=ts>
22:57:59.009 T:1682010880 ERROR: AddOnLog: PVR IPTV Simple Client: Unable to load playlist file 'http://vippro.wezzy.pro:8888/get.php?username=pro352&password=Scarmbled&type=m3u_plus&output=ts': file is missing or empty
I really do not see what this has to do with KODI.
You are being refused access by your provider because of a missing link or invalid URL:
Please take it up to them.
Additional info: when I re-paste the link re-configuring the link in simple client I get a message “restart neede” which is expected and on right hand corner I see that all channels are loaded, this also prooves the link is fine. I tried to gather the debug doing this but it gets larger than 1mb and it doesnt allow me to collect.
Have you read all the intent or only looked at the logs?
May I ask you who your IPTV provider is and could you please provide a full
debug log (wiki) as previously requested.
Read here to find out how to submit (easy way):
Log_file/Easy (wiki)
Here (for the hard way!):
Log_file/Advanced (wiki)
Don't forget to read this:
banned add-ons (wiki)
I dont want to paste the debug link here as stated in my message. How can I send the link to you?
MODs do not accept personal logs. This is not how this forum works.
By the way, you reported me as rude when nothing I said was remotely so
I must therefore withdraw myself from this thread and conversation with you.
Good luck in getting assistance.
Using the paste bin for the log was is the way to go.
No full debug log, no issue
Here you go:
https://paste.kodi.tv/ofogotoxot
OTinley, I reported you as your replies left me the impression that you dont read all intent and jump to conclusion. Since you are the MOD, maybe you can take that as a feedback.
Cheers
You have banned Addons therefore no more support
(2018-12-21, 23:00)kilyaran Wrote: [ -> ]I reported you as your replies left me the impression that you dont read all intent and jump to conclusion.
Apparently there are more people that do not read. Things like the Kodi
forum rules (wiki) that clearly outline Kodi's stance on video piracy. So either fully clean up your Kodi device, or find your support elsewhere.
