2018-12-17, 19:16
I have been experiencing an issue where files in a playlist will sometimes play with no audio and then the video will freeze. After some experimentation, I have found that it seems to come down to when changing AC3 formats. If I am going from AC3 5.1 to AC3 5.1, things work fine, but if I go from AC3 5.1 to AC3 2.0 or the other way around, the problem happens. Below is a small section of my log file where I just switch between two files that will trigger the issue. I can provide a full log later, but I don't have time at the moment to remove my Plex server token.
This is on an nVidia Shield TV running the 7.2 firmware, though the issue was also present on the older 7.1 firmware. To the best of my knowledge, this issue has been present in RC1, RC2, and RC3, and probably Beta 5, but I don't recall for sure on that one. These same files worked correctly on Kodi 17.6 and below, using the same pass-through settings as Kodi 18. The only addons I have are a modded version of the Titan skin, and PlexKodiConnect (stable 2.4.11, though the issue also is present on the beta 2.5.5) and the required support addons for each; again, an almost identical setup worked correctly on Kodi 17, and most of the Kodi 18 alpha and beta cycle. The Shield is getting the files from a NAS on my LAN and both are connected via a gigabit connection, so bandwidth should not be the issue. I will try to provide any additional information requested when I get home from work.
* log snippet removed *
