(2018-12-19, 00:06)fb42000 Wrote: [ -> ]There is an error showing with loading your profile, check your advanced settings, Line 13, for a close out tag as it will currently ignore this setting if not - may be the lead up to issue.
I played around with PIN settings last night - the prompt on my setup only came about when expected - ie i pin protected music and selecting music got prompt, no other etc etc. so cannot replicate your issue as i understand it - so not entirely sure it is a specific skin issue, it may be more of what this skin is loading when calling for 'something' as opposed to Estuary (which is a simpler skin in terms of window linking)
The IPTV addon is trying to load a control and display as text viewer but it cannot get the info to display - have you set an EPG location or can you turn this off within addon settings? I cant dual load IPTV simple as I run TVH and you cannot have two PVR clients running so I'm blind to this addon's settings.
You could also do with trying to find remnants of plugin.program.advanced.emulator.launcher and make sure it is uninstalled or updated as it is failing to find it - so it may be looking, pin prompting you but then failing to find. Your favourites is calling for it so at least remove it from your favourites
Using a file manager to access the replacement files, assume you have samba/ssh setup to access your box, if you download my repo to your PC with samba / ssh access (go to my github address in first post, click on Clone or Download green button, select download Zip, extract, then find the files to replace; 1080i/includes.xml 1080i/service-LibreELEC-Settings-mainWindow.xml media/Textures.xbt. Log into kodi box over samba/ssh file manager, go to /storage/.kodi/addons/skin.mimic/ the folder layout then is the same as above extracted folder. Copy and allow to overwrite the above into the same folders ( it may be worth taking a backup copy of your includes and Textures files before JIC!)
fb42000
Thanks for the details.
1. The advanced settings file with the line 13 problem is actually from CoreElec !
So what suggestions do you have to change it to something more palatable? There only are 11 lines in advancedsettings.xml file.
Edit. I have had the PIN prompt issue with LE/Win7 as well, in the past. Haven't tested LibreElec lately, but just looked again at my Win 7 Kodi 18 beta3 setup with Youtube plugin updated to v6.2.3, and the extra PIN prompts issue seems to have gone away.
However when I manually updated Youtube plugin to v 6.3alpha3 and then back to v6.2.3 (the official Kodi rep is still at my previous v6.2.2), the PIN prompt issue is there, and occurs frequently with YouTube plugin.
CSkinSettings and later, CApplication- start.xml have problems too. And JSON parse error: Setting.Details.SettingList.
But I don't know what they mean.
2. Will turn off EPG in PVR settings...don't use EPG anyway.
Edit. There really is no EPG off setting in PVR IPTV Simple Client. I turned off local cache under EPG menu, but don't think it has made a difference.
3. Will try to locate plugin.program.advanced.emulator.launcher and delete/update it, and check my Favorites folder to identify the link/add-on responsible.
Where usually is this emulator, and what does it do?
Edit. This plugin isn't under .Kodi/userdata/addon-data like others where it is supposed to be.
However I cleaned out many plugins and packages etc from above userdata folder and also from add-ons folder, then reloaded Twitch from Kodi repo (which still shows the same "deprecated" error under Kodi log.)
There might be a slight improvement, but I still get the PIN prompt when switching menus, or within 1-2 sec of highlighting a menu.
Most my menus are customized on the Mimic home screen, and linked mostly to Youtube, but also to Twitch, Facebook Media add-on and also couple of video addons like Daily Motion.
I will look into the Favorites folder deletions ...but I think I had these errors even before I set up this folder.
4. Will do the zip/replace. Does it matter if I don't use 1080 but just 720p?
Edit. I will first have to switch to a LibreElec build on my 2/16G Leelbox ATV8.1 voice remote that arrived today, one day earlier !
Which LibreElec version(s) have you tried? For Leia I believe my only choice for a generic S905(W) box is the @balbes150 builds.
