Full Version: Found two bugs
Hi, I'm using the chroma skin and I like it a lot.
But I found two pretty annoying bugs. First, In some addons the empty cdart appears in the list view.. If I'm not mistaken in another of your skin there is the possibility to disable the empty cdart, would you be able to do it also on chroma?Second,sometimes when browsing through any list the vertical scroll bar disappears. Thanks.
