2018-12-21, 06:38
After upgrading to 7.2.1 on the NVidia Shield and launching KODI, I tried playing a vídeo file, whole system hanged with a freezing sound alongside it, I had to make a "cold" power off (plug the cord), the system is back on and but KODI wont start. It just stays in the back ground unaccesible.
Version 18 RC3 (tried with RC 4 nightlies and its the same)
When I installed latest RC4 nightlies, it prompted the "first start" but then it soon minimized and wont open.
Anyone having this issue?
Also when I launch KODI and it minimizes, 80% of my menu icons go grey for a couple of seconds.
After checking the kodi logs through SMB I see this:
What the hell?
Quote:04:41:26.611 T:155082265840 NOTICE: -----------------------------------------------------------------------
04:41:26.612 T:155082265840 NOTICE: Starting Kodi (18.0-RC4 Git:20181220-7439ef5). Platform: Android ARM 64-bit
04:41:26.612 T:155082265840 NOTICE: Using Debug Kodi x64 build
04:41:26.612 T:155082265840 NOTICE: Kodi compiled 2018-12-21 by Clang 7.0.2 (https://android.googlesource.com/toolchain/clang 003100370607242ddd5815e4a043907ea9004281) (https://android.googlesource.com/toolchain/llvm 1d739ffb0366421d383e04ff80ec2ee591315116) for Android ARM 64-bit API level 21 (API level 21)
04:41:26.612 T:155082265840 NOTICE: Running on NVIDIA SHIELD Android TV with Android 8.0.0 API level 26, kernel: Linux ARM 64-bit version 4.9.109-tegra-g29568bc
04:41:26.612 T:155082265840 NOTICE: FFmpeg version/source: 4.0.3-Kodi
04:41:26.612 T:155082265840 NOTICE: Host CPU: ARMv8 Processor rev 1 (v8l), 4 cores available
04:41:26.612 T:155082265840 NOTICE: Product: darcy, Device: darcy, Board: unknown - Manufacturer: NVIDIA, Brand: NVIDIA, Model: SHIELD Android TV, Hardware: darcy
04:41:26.617 T:155082265840 NOTICE: External storage path = /storage/emulated/0; status = ok
04:41:26.617 T:155082265840 NOTICE: ARM Features: Neon disabled
04:41:26.617 T:155082265840 NOTICE: special://xbmc/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
04:41:26.617 T:155082265840 NOTICE: special://xbmcbin/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
04:41:26.617 T:155082265840 NOTICE: special://xbmcbinaddons/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets/addons
04:41:26.617 T:155082265840 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
04:41:26.617 T:155082265840 NOTICE: special://envhome/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files
04:41:26.618 T:155082265840 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
04:41:26.618 T:155082265840 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
04:41:26.618 T:155082265840 NOTICE: special://logpath/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
04:41:26.618 T:155082265840 NOTICE: The executable running is: /data/app/org.xbmc.kodi-JeJspBLsw9LhA2et2Rag1A==/lib/arm64/libkodi.so
04:41:26.666 T:155082265840 NOTICE: Local hostname: 192.168.2.98
04:41:26.667 T:155082265840 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
04:41:26.667 T:155082265840 NOTICE: -----------------------------------------------------------------------
04:41:26.667 T:155082265840 INFO: loading settings
04:41:26.667 T:155082265840 ERROR: CProfileManager: error loading special://masterprofile/profiles.xml, Line 0
Failed to open file
04:41:26.668 T:155082265840 NOTICE: special://profile/ is mapped to: special://masterprofile/
04:41:26.668 T:155082265840 FATAL: unable to load profile
What the hell?
