2018-12-23, 20:28
Hi, I recently built an HTPC with old hardware, motheboard is an Asrock 939A790GMH with IGP HD 3300 vga (DX10 vga).
I got problems with 1080p movies, checking info during playback shows that DXVA is not used and CPU isn't sufficient to handle those movies.
So I checked the log and in fact I can read:
NOTICE: CRenderSystemDX::CreateDevice - Your video driver doesn't support DirectX 11 Video Acceleration API. Application is not be able to use hardware video processing and decoding
In wiki I read: GPU hardware must support at least level DirectX version 9.0c however the GPU software drivers must support the DirectX 11 Feature Level 9.1 (which means the DX11 API has been implemented in the GPU software driver to be compatible with DX9 hardware)
https://kodi.wiki/view/Supported_hardware
So I understand that vga is DX10 while drivers must support DirectX 11 Feature Level 9.1 to get DXVA.
My question is: can modded drivers fix this lack or it's an hardware limitation, so no possibility at all to get DXVA working?
