2018-12-28, 08:29
Hello, I am a user from China. I don't know English. After a few days of use, I feel that kodi is very easy to use. I also found some problems. These questions are the conclusions I got after 3 days of testing. I hope your products can help. For more users, the following content is completed with google translation, I hope you can understand.
Recently bought a Sony Z9F, according to the guidelines of https://forum.kodi.tv/showthread.php?tid=336272#, the installation package of kodi was installed normally, and kodi played the 4k UHD original file on the mobile hard disk, I tested The Mission Impossible Fallout 2018 2160p UHD Blu-ray HEVC TrueHD 7.1 Atmos-Thor@HDSky, the test file has 94G. Methods as below:
1. Connect the mobile hard disk to the USB3.0 port of the TV. The direct playback is smooth and there is no problem.
2, the mobile hard disk is connected to the router, through the wifi 5G wireless network, using FTP mode playback is also very smooth, without any problems.
3, the mobile hard disk is connected to the router, through the wifi 5G wireless network, using SMB mode, NFS mode to test separately, play video card, about every 10-30 seconds will load the cache, Caton circle. The CPU and memory usage of the router is also very low during playback. I also enabled caching according to https://kodi.wiki/view/HOW-TO:Modify_the_video_cache, but the aging time is extended by 1-3 times. Will be stuck.
With the same SMB mode, NFS mode, playing with apple tv 4K is very smooth, without any problems. There is no problem with playing on a computer. It can be confirmed that there is a bug in kodi's playback of the SMB protocol and the NFS protocol. Please check it out.
Thank you
Thank you
