Full Version: dts hd and true hd
hallo
i have a minix u9 tv box.(android 6)
when i buy it is has kodi 17.3 installed.
i had the options in setting true hd and dts hd.(but it has some problems for playback)
now it is update to 17.6 and i try also the 18 beta versions
but on this version the option true hd an dts hd are juist gone (only dts and dolby digital)
 when i use coreelec (linux based kodi os for this box) i have all options and works just fine.
why kodi don't support true hd and dts hd on this android box
Because the box android firmware is broken and what was sold to you has major flaws ... return it if you can.
