Hi there,
Spite kodi still crashing on mibox 3 with oreo the leia rc3 i can use kodi
But i have a issue with a particular file through plex kodi connect or playing directly by source by going to file manager to my NAS file.
it plays sound but no image
i installed ffmpeg on windows and played the file with no issues through plex and with ffplay with file on my pc.
here is the type of file
http://prntscr.com/m14t0a
i cannot upload the log because it says is bigger than 1Mb on kodi log uploader
thanks for the help
Without log no one can help you.
1) Stop kodi
2) Start kodi
3) Play the file
Now directly upload the log. Make sure Component Logging is disabled - this will spam the entire log
(2018-12-30, 12:34)fritsch Wrote: [ -> ]Without log no one can help you.
1) Stop kodi
2) Start kodi
3) Play the file
fritsch
Thanks for the reply
i have updated to RC4 and still cant play the video file.
here is my log
https://paste.ubuntu.com/p/zg2crjmcPC/
i noticed also something strange as i long press right on mibox remote a random movie starts playing, how can i change not do that action, sorry i know its offtopic.
edit:
i have removed the hardware acellaration, when i disable media codec surface, the problem persists, when i disable both surface and media codec, the video plays but with lag.
how can i solve this? buy an nvidia? cant afford it
thanks
Sounds like an add-on issue
(2019-01-03, 00:09)Norin_Radd Wrote: [ -> ]here is my log
Seems like your network setup needs some permissions attention?
The list of http errors 22 is endless.
(2019-01-03, 00:15)Martijn Wrote: [ -> ]Sounds like an add-on issue
seems like so, someone told me already. i will report to the devs of the addon.
(2019-01-03, 00:19)Klojum Wrote: [ -> ] (2019-01-03, 00:09)Norin_Radd Wrote: [ -> ]here is my log
what do you suggest for me to fix this?
thanks for the repplies
(2019-01-03, 02:33)Norin_Radd Wrote: [ -> ]what do you suggest for me to fix this?
Not sure, but I don't see the need to use the http protocol for network file access to begin with. Is this because of plexconnect or something else?
I prefer to use a proper file network protocol like SMB, or better yet, NFS.
The http 22 errors are caused by PlexKodiConnect and the music library still being enabled, but unfortunately have nothing to do with the issue here. More details:
https://github.com/croneter/PlexKodiConnect/issues/14
I'm afraid this seems to be a Kodi issue.
PKC only hands over the file to kodi for playback. That succeeds. Then it's entirely up to Kodi to play the file. Best test: circumvent PKC and try to directly play the file - which failes here...
Quote:But i have a issue with a particular file through plex kodi connect or playing directly by source by going to file manager to my NAS file.
Post a
Debug Log please playing this video directly.
(2019-01-03, 13:28)fritsch Wrote: [ -> ]Post a Debug Log please playing this video directly.
Sorry for not replying earlier... i was starting over from scratch my install with nfs and my setup is not yet complete.
I have done what was asked, here is my log
http://paste.kodi.tv/sonasonali
it has a lot of errors, but the specific one is for the movie Iron master i think it is: (ERROR: Control 120 in window 10153 has been asked to focus, but it can't)
i have installed latest development build of kodi master of 7/1/2019 and changed the xbmc.gui number on the addon.xml of the kodi skin.
edit: would like to rephrase that video plays with sound is just the image that turns into a black screen.
fritsch
did you had time to look into this?
can you look once again?
(2019-01-18, 19:13)fritsch Wrote: [ -> ]Nope - no idea.
So it seems kodi cannot play this particular file.
