I donated to tinymediamanager to be able to use rotten tomatoes ratings which i find far superior to imdb.
Sadly the implementation seems broken if u use omdbapi or universal movie scraper both will add the rating and counted together so for instance 12 years a slave will have a rating of 95347 (it's at rotten tomatoes 95% 347 counted)
Also the audience score is not working at all, both (the audience and critic rating) works correctly in KODI
It's a shame as i need a mass updater for my movie collection which can replace the imdb ratings in my nfo's.
sorry, but I need more information to help you.
a) which scraper to you use?
b) which tmm version to you use?
c) do you have any logs where I can search for the error? (use
https://paste.kodi.tv/ to post the logs)
btw: rotten tomates closed their API from being used for free (even for open source projects) - so I wonder where you get the data from.. (omdbapi?)
(2018-12-30, 19:52)mlaggner Wrote: [ -> ]sorry, but I need more information to help you.
c) do you have any logs where I can search for the error? (use https://paste.kodi.tv/ to post the logs)
hello as requested the answers for troubleshooting.
a. Scraper is kodi universal movie scraper 4.1.11
b. tmm version is 2.9.14
c.
https://paste.kodi.tv/egayeperop.kodi
The resulting nfo
https://paste.kodi.tv/hajaxevinu.kodi
I have no idea about rotten tomatoes in settings there is only a omdbapi key asked which i got at
www.omdbapi.com the free one.
below a snippet and it seems all data is there only it gets parsed incorrectly
</GetRTDefaultRatingById><GetRTRatingsById><details><ratings><rating name="tomatometerallcritics" max="100"><value>95</value><votes>347</votes></rating><rating name="tomatometerallaudience" max="100"><value>90</value><votes>139678</votes></rating><rating name="tomatometeravgcritics" ><value>8.9</value><votes>347</votes></rating><rating name="tomatometeravgaudience" max="5" ><value>4.3</value><votes>139678</votes></rating></ratings></details></GetRTRatingsById>
thanks for the example - have to investigate whether the problem is on our side (parsing of the kodi scraper result) or at the kodi scraper side
Ok thank u,
I believe the kodi scraper is correct btw as it works just fine in kodi
wow this scraper has a bunch of setting.. to be able to reproduce, could you send me the file
tinyMediaManager/data/scraper_metadata.universal.conf to
[email protected] please?
I am not able to get the right settings to reproduce your issue
ok, I finally found it.
seems like Kodi changed the scraper infrastructure along with the changes to the NFO for ratings:
we've implemented the scraper parser to accept XML in the form (source
https://kodi.wiki/view/Scrapers#.3CGetDetails.3E):
xml:
<rating></rating>
<votes></votes>
but with your scraper we get:
xml:
<GetRTRatingsById>
<details>
<ratings>
<value>95</value>
<votes>347</votes>
</rating>
</ratings>
</details>
</GetRTRatingsById>
well, needs a bit of work to make the parser aware of both styles
(2019-01-05, 12:50)mlaggner Wrote: [ -> ]we've implemented the scraper parser to accept XML in the form (source https://kodi.wiki/view/Scrapers#.3CGetDetails.3E):
That page has had no meaningful updates in 4 years. I would be very hesitant to rely on it. I think investigating the code would be better.
well, its about 4 years ago when I created the scraper parser
regularly checking the wiki if anything has been changed would need too much time :/
Yes, the "new" format has never been implemented there... till now
Should work again in next version....
Remember: TMM v2 only supports ONE - the frist - rating.
Only in v3 we have multiple....
Is this still in the works?
I noticed that no mater the
Preferred Rating I set, I always get TMDB Rating. I can't get IMDB or RT.
A small heads up. I was poking around and noticed what I think is a typo in the
tmm.prop file.
javascript:
movieSetFilterW=0
movieSetFilterX=0
movieSetFilterY=0
nessageDialogH=695
nessageDialogW=835
nessageDialogX=825
nessageDialogY=180
ratingEditorH=166
ratingEditorW=477
I'm guessing
nessageDialog should be
messageDialog?
(2019-01-24, 08:49)mlaggner Wrote: [ -> ]@akovia fixed the type (but this had never caused any error since it has been written and read "wrong" ).
for the rating I am unsure what the problem is...
I didn't think it was causing any trouble, but thought you might like to know if you happened to overloook it.
Quote:do we speak about v2 or v3? if v3 -> could you open an issue at gitlab (https://gitlab.com/tinyMediaManager/tiny...ger/issues)?
I feel like I'm overlooking something here which is why I posted here first before posting a bug, but It's posted now.
