2008-06-08, 19:28
2008-06-08, 21:35
Where does that link come from?
2008-06-09, 01:41
I found this on the Wiki page hope it helps:
ASX format
Sometimes if a stream has a .asx extension it will work fine on your Windows computer but XBMC will not play it. In these cases it could be that that .asx is not actualy a stream but instead just a playlist that redirects to a other stream (ie. the real stream). To play this stream you must download the .asx file to your computer and open it in a text-editor to find the true direct link, then add that link to a .STRM file which then can be played by XBMC.
ASX format
2008-06-10, 21:55
mms://213.251.134.195/data/5351f296481ae30009d2910f6035cf73.wsx?wmcontentbitrate=600000
to the the great genius plz help me play this link in xbmc...
thanks
ta
thanks
ta
2008-06-10, 23:46
Nobody can help if you persist in showing only a link.
Where is the link from ?
Show me the webpage.
What`s the address ?
I need to see it in it`s original state.
2008-06-11, 00:08
the website address is
http://www.desitvstreams.com/
if you can make the plugin that would be wonderful..
much appreciated
london_boy
much appreciated
london_boy
2008-06-13, 22:02
please help me to use the mms link in my previous post.
ta
ta
2008-12-31, 12:06
Does anyone have a solution to this? I'm working on creating a plugin for http://www.bwcinema.com. The ultimate play (which is unfortunately password protected with an account so I can't link to it) points to a mms://xxxx/xxx/xxx.wmx?xxx stream.
I've found that the best way to play these is to create a .strm file and add the mss://xxx to the file and play that file. Unfortunately, I don't know how to do this via a plugin in python.
Voinage.. I've been following your Plugin tutorial and have everything scrapped. All I need to do now is figure out how to actually play this stream. Any advice would be greatly appreciated. Please let me know what information you need and I'll do my best to provide as much as I can.
2009-11-19, 01:00
sorry to reopen this thread -
http://www.desilive.tv/server.php?ch=stargold
the above url has a wsx stream embedded
http://213.251.176.181/data/de9504c64948...WMExt=.asf
can someone tell me how to open this stream file and get the wmv or media url to play?
2010-01-16, 17:20
bittihuduga Wrote:sorry to reopen this thread -
Supposedly you should be able to make a file with .strm extension, copy the embedded url in the file and save it under your "XBMC\userdata\playlists\music" folder..
That's the only solution i have ever seen in this forum to the problem...one issue though...it dosn't work.
I have tried to do it with several .asx streams (http://www.listenlive.eu/denmark.html all the stations starting with DR) and it has never worked. It plays for a second a then it stops. If i wait a couple of minutes, sometimes its suddenly comes to live but not always..
I don't get it and the dev's apparently don't care mush for this particular issue..
2010-01-18, 20:56
yes, i tried the same - created a strm file and put my .wsx url in it.
it failed to work
but the same url worked when used within a plugin.
not sure why strm fails
it failed to work
2010-01-19, 01:24
bittihuduga Wrote:yes, i tried the same - created a strm file and put my .wsx url in it.
it failed to work
Hello!!
i have the same problem with asx files
i wish could see the following in XBMC:
http://ondacadiz.en-directo.com/OndaCadiz.asx but fails
i downloaded the files and inside of another asx was the following:
http://win.2.c2.audiovideoweb.com/va92winlive2319
http://win80il.audiovideoweb.com/1c2winlive6748
http://win82il.audiovideoweb.com/1c2winlive6748
i tried to create a strm file in xbmc but fails
Can anyone help me?
Thx
PS: sorry for my English
2010-05-30, 18:54
guys, I'm trying to get the BP oil leak livestream to play in my XBMC (as a substitute for an aquarium I guess...)
asx source file: http://mfile.akamai.com/97892/live/reflector:46245.asx
raw stream address according to the .asx file:
mms://a246.l9789246245.c97892.g.lm.akamaistream.net/D/246/97892/v0001/reflector:46245
I tried to copy this mms stream into a .strm file and play it with XBMC but it won't play
2011-11-04, 08:11
Anyone found any way of playing streams with .wsx extension.?
