Reason: different firmware. Different way of implementing Mediacodec-Surface. Kodi uses exactly the same path for both devices.
(2019-01-04, 17:50)fritsch Wrote: [ -> ]Reason: different firmware. Different way of implementing Mediacodec-Surface. Kodi uses exactly the same path for both devices.
It is funny that on v17.6 DVD ISO played perfectly on H96Pro+ media player and choppy on Philips TV. Now it is vice versa. No luck to satisfy both devices and obviously there were some changes in MediaCodec within KODI path from 17.6 to 18 RC 4.
Why not contirbute? Everything you need is here: github.com/xbmc - you even have both those devices!
(2019-01-04, 19:53)fritsch Wrote: [ -> ]Why not contirbute? Everything you need is here: github.com/xbmc - you even have both those devices!
I would be happy to contribute but I don't have experience and I don't know where to start. I will be glad if I manage to develop fix for H96Pro+ to work fluently with DVD ISO. I will explore given link. Do you have more info for me as noobie in this field?
(2019-01-04, 20:26)fritsch Wrote: [ -> ]Low hanging fruits are perhaps here: https://github.com/xbmc/xbmc/blob/master...ce.cpp#L71 <- changing that to more
Btw. you could also start with a Debug Log, enable video component logging (additional to debug log) and post your log with that. In order to not "fool" the results of this log, please enable debug logging via advancedsettings.xml - we don't want the debug overlay on screen as this puts additional load on especially ByPass render devices, see here: https://kodi.wiki/view/Advancedsettings.xml#loglevel this goes to your userdata/advancedsettings.xml
Here it is:
https://paste.kodi.tv/ifewutesuy.kodi
Enabled video component logging through GUI and logging thorugh advancedsettings.xml with parameter 1:
<loglevel>1</loglevel>
Anything helpful inside?
I see - the resolution is quite minimal.
Could you please disable Mediacodec and Mediacodec Surface first? And try to play it back again. It should work with the SW decoder quite well.
(2019-01-05, 12:28)fritsch Wrote: [ -> ]I see - the resolution is quite minimal.
I tried and it still stutters. Less than with enabled MediaCodec but still visible.
How to change buffer in code and to try with higher number?
clone kodi, change the number, push it to your fork - I will build it for you. Just tell me the branch on your github.
(2019-01-05, 19:13)fritsch Wrote: [ -> ]clone kodi, change the number, push it to your fork - I will build it for you. Just tell me the branch on your github.
Thanks but please help me in very first step installing terminal (cli) on Windows 10 to start preparation step of installing SDK and NDK needed for branch coping and changing the code. From where and how to get and install cli?
No need to build for now. Just fork on GitHub, change the file, push it. Our Jenkins will build.
I changed the file: RendererMediaCodecSurface.cpp
It is slightly different than one you proposed previously, some changes were already done (maybe they will also fix my problem) and buffers are now separated to max buffer size and optimal buffer size. I put 8 for both. Please, compile it to test it on my device.
I pushed and commit changes from my github account:
Stile35 wants to merge 1 commit into master from Stile35-patch-2
Do you need some additional information in order to compile it?
