Hi folks,
I'm brand new to Kodi and TTM. Can someone point me to a guide that helps me set up TTM to work with Kodi? I'm a bit confused about the export thing....the FAQ or the Wik
Sorry for the total newb question, but I'm unable to find anything about it in the FAQ or Wiki.
Thanks,
Boeniz
This guide doesn't explain at all what the settings need to be in Kodi and TMM to get them to work together. Any other place that I can look, or could you please just explain it.
(2019-11-15, 05:32)Karellen Wrote: [ -> ]@sbernstecker
(2019-11-15, 04:37)sbernstecker Wrote: [ -> ]This guide doesn't explain at all what the settings need to be in Kodi
Please follow the guide here... https://kodi.wiki/view/HOW-TO:Create_Video_Library
Thank you for the answer to my question, I know how to setup a library, I am just wondering what settings need to be adjusted in TMM and or Kodi so they the both work together so I can maintain my library.
(2019-11-23, 01:59)sbernstecker Wrote: [ -> ]I am just wondering what settings need to be adjusted in TMM and or Kodi so they the both work together so I can maintain my library.
From the Kodi view point, you just need to download artwork and create your nfo files with TMM, then run an update library in Kodi which will find the local files.
If you are wanting "more" or some other function, then the TMM developers will need to answer.
