2019-01-08, 19:38
2019-01-08, 19:38
2019-01-09, 18:59
Couple questions - are you setting the resolution/fps on the shield or within kodi?
In either case, are you manually setting the fps to 24, or are you letting kodi switch the refresh rate when you play 24fps content?
I have an older gen model of that same TV (E6), and I haven't experienced what you are with my shield and 24fps content w/ 4k resolution.
I'm running the latest 7.2.2 test image however for the color space switching.
2019-01-09, 20:22
