Full Version: Subtitle included in video stream.
I have noticed that videos with subtitles interlaced in video streams will not play.
While using mpv player or vlc player on the computer it is working just fine but once connected to kodi on Raspberry pie the subtitle is not recognized.
All the subtitle settings are on!
Have you any solution for that matter?
Thank you.
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Here is my debug log!
The video is named: "as an example".
jodavipoyi (paste)
