Full Version: Nightly Kodi 18 Build Causes Duplicate Entries in TV Series Listing
I ended up needing to try a nightly build (for reasons) and found a new behavior that I haven't seen before with v17 or any of the RC v18 builds to date around the TV Show library.  This is on 20190108-adb55e29fd.  I thought I'd go ahead and report it here (with a log), but if there's a better place to report it, I can submit it there too (i.e. Github I suspect).
Old Behavior:
If I had the same TV Show in two different sources (i.e. E:/NextPVR/TVShows/Black Lightning and E:/PlayOn/Black Lightning) Kodi would merge those into one entry on the TV Show listing.  BTW, the use case here is if for some reason I miss a recording of a show, I get it from either the channel's web site or Amazon and then record it using PlayOn.
New Behavior:
If a TV Show folder (even an empty one) is in two different sources, The TV Show shows up twice in the TV Show listing.  If I delete one of the listings from the database, both disappear, and if I rescan they both reappear.  The only way to resolve this is to delete the folder from one of the two sources.  Then I get one entry as expected.
I can obviously adjust my workflow to account for this if it was an intentional change, but in case it was unintentional I wanted to post this.  Here's a debug log with a update video library scan.  Black Lightning is the particular show I tested with.
https://paste.kodi.tv/avetihunub.kodi
Thanks, this was reported in https://github.com/xbmc/xbmc/issues/15212
and there should be a fix with https://github.com/xbmc/xbmc/pull/15200 which will be included in RC5
THank you for reporting it. I thought it was just me.  And couldn't find the right area of the forum to report the issue.
