when you install the drivers it is normal that a USB device was detected but can not be installer. but the remote control work
have you installed the update ?
Ok, manually installing the USB Device as a Microsoft Infrared HID Device worked great. The new drivers also install a keybord (ie, something is new on this install). Appears to be working on my HTPC.
Thank you both!
Setup install Remotexbmc1.5 - Stable Version For Xbmc :
download here
Remote control for xbmc pc : REMOTE XBMC 1.5 drivers include + news Keymap.xml.
For the original remote control xbox change USB + xbmc pc rev 13239 or 12882. version 1.5
- Connect your ir in USB
- install the drivers and restart
- insert the keymap.xml in the folder USERDATA and run the REMOTE XBMC 1.5
Please send me your comment.
thank all for your help.
Is it possible to program the remote to turn on my HTPC using the XBox IR receiver?
Is this driver ok to use on Windows XP x64
or Vista x64?
turn on your htpc when it is paused it is possible to do
roeroe Wrote:Is this driver ok to use on Windows XP x64
or Vista x64?
Windows 98/Me,Windows 2000/XP for vista I do not think.
mode2006 Wrote:turn on your htpc when it is paused it is possible to do
So you mean, if I place the HTPC on a hibernate or sleep mode, I can press a button on the remote and it will "wake" the HTPC up?
yes but we have created the fonction because it does not exist at the moment
I don´t believe that it possible, because it´s a hardware thing, not a software. Bacause the remote reciever must have ACPI Support, and that´s in the flashrom from the reciever.
i agree
