Full Version: Video OSD problem
Today I just started using Confluence and everything was working fine until some minutes ago.
For some unknown reason, the OSD when I play videos only shows the buttons.
It doesn't show the time bar nor the fanart.
I know for a fact that it did show them before, but I can't find a solution.
Any other skin I test works, but Confluence OSD doesn't.
Any ideas on how to solve it?
Debug log please?
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
