No member of video and not of audio:
http://paste.ubuntu.com/p/rNQyz9kmcq/
BUT the kodi.log you are posting shows that this is running as "kodi" user while the above is done by "mau" - so most likely not related
/home/
kodi/.kodi/temp//kodi.log
The log is full with decoding errors, and as 17.6 is out of support anyways -> upgrade to 18-rc5 and post another log
Make sure to set the device to: GSM W2753VC on HDMI
Disable Passthrough
And now:
Set Audio to Fixed and Samplerate to 48000 hz and speakers to 2.0
If this does not work, post the output of: amixer
Edit: I hope you pressed "+" / "-" several times on your remote already to see that it is not muted ...
Then we can do nothing for you.
sound testing works as root user but not as kodi
then fix your permissions, please.
kodi already has access to audio
kodi@ubuntu1:~$ id
uid=1006(kodi) gid=1006(kodi) groups=1006(kodi),5(tty),20(dialout),24(cdrom),29(audio),30(dip),44(video),46(plugdev),100(users),147(input)
Post your guisettings.xml in .kodi/userdata/
<fvolumelevel>0.577777</fvolumelevel>
max it to 1.0 - but I really think this is not the problem.
How did you verify that root audio works? With kodi or from command-line with aplay?
it seems now it's working for the default sink (headphones jack) but not for HDMI output - but this is the same for root and kodi so I can live with this for some time
the only thing i did was a
rm -rf /home/kodi/.config/pulse/
but it still uses ALSA and not pulseaudio so I don't really know what fixed the jack audio...maybe it was always working as I was checking it via hdmi...don't know for sure
thank you for all your help, fritsch !!!
