2019-01-14, 00:25
2019-01-14, 00:25
2019-01-14, 00:32
A (partial) kodi debug log (wiki) file and/or crash log would be of better use than a static picture of a screen we all know.
2019-01-14, 00:36
(2019-01-14, 00:32)Klojum Wrote: [ -> ]A (partial) kodi debug log (wiki) file and/or crash log would be of better use than a static picture of a screen we all know.Sure, I just was going to bed and experienced this. Just wanted to share it before I am in bed (so that potentially, others can see that they are not alone ).
Best reagrds
Manuel
2019-01-14, 20:50
I'm getting the exact same screen. I have just fresh installed for first time on this console too.
How are we able to provide a log when we're unable to launch the app to do so?
2019-01-14, 21:15
(2019-01-14, 20:50)MancnProud Wrote: [ -> ]Hi,Hi, here's a help page for that: Log_file/Advanced (wiki) (changing the advancedsettings.xml and getting the log file here: %LOCALAPPDATA%\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalCache\Roaming\Kodi\kodi.log) but I assume that this is pretty much for a beginner. It would be easy on a normal PC but seems to be a lot more work on the Xbox.
I am not sure when I have the time to deal with it myself.
Manuel
2019-01-15, 00:26
My "solution": I deinstalled Kodi and installed it again. Now it works again.
2019-07-03, 20:59
(2019-01-14, 21:15)manuelkuehner Wrote: [ -> ]It's impossible on Xbox because Kodi is the only way to access the location of the xml file. I'm stuck with a broken Kodi install again. I LOVE setting it up from scratch every other day.(2019-01-14, 20:50)MancnProud Wrote: [ -> ]Hi,Hi, here's a help page for that: Log_file/Advanced (wiki) (changing the advancedsettings.xml and getting the log file here: %LOCALAPPDATA%\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalCache\Roaming\Kodi\kodi.log) but I assume that this is pretty much for a beginner. It would be easy on a normal PC but seems to be a lot more work on the Xbox.
Manuel
