2019-01-14, 05:33
Basically, I want the renamer to use media source in it's rename protocol only if Web-DL files are detected.
At the moment I am detecting many blu-ray media sources and having to manually remove "blu-ray" from the title. I have excluded "blu-ray" under bad words, but I suspect this is for title detection not renaming, as it hasn't helped.
Can we implement a feature or rename code to write if something is true not just optionally detected.
This is my re-name code if it helps:
$T {($U)} [$Y] {($3)} $F{-$H}-$A{-$S}
Maybe something like {-(web-dl=True)$S} could work?
