Full Version: New Aeon Madnox Artwork - Release
I was adding a few new Movie backgrounds to my Madnox set up and though I would share them if anyone wants to use them. I use full screen backgrounds but I have included both full screen and Madnox platform backgrounds
Enjoy.
Thanks very much for this.  Any chance for a zip to make downloading a bit easier?
(2019-01-14, 16:55)bobrap Wrote: [ -> ]Thanks very much for this.  Any chance for a zip to make downloading a bit easier?
 Sure, here you go
https://1drv.ms/f/s!Ap9YPoMesMmjgoky3S3GbABeIotnrw
Thanks much, appreciate it!
Thanks, these are great especially the movie ones I use them with Silvo mod though.
Keep them coming.
Yes, thanks for these.... just curious to what program/effect you are using to create these?
I thought that they were just normal images at first and that the skin was putting a mask on top of them.....
But apparently, after seeing yours, you may have started with a normal image, and added the mask as a layer, then saved image.
I see you also included fanart of same image with mask but bottom not blocked out as with Modnox Platform backgrounds.
Is the Madnox Platform an addition process or another mask/layer?
Hi yes, I have two different photo shop psd files with all the layers included to do the affect for Madnox platform style and full image.
Cheers
