Full Version: ARM boards running Operating System from SD Card - do EPG updates ruin the card?
Hello.
I am hoping to build a new TVHeadend server, based upon an Odroid HC2.
I was going to use Openmediavault, running from a good quality A1 32GB SD card, and then a large Harddrive for recording.
Openmedivault does very little writing to the SD card, once it is up and running.
However, I am a bit worried about TVHeadend - will the daily EPG updates and constant scheduling wear the SD card out prematurely?
