Full Version: XBOX one KODI Leia RC5 - Screen size resetting issues / best audio options
Hello! I'm very impressed how far Kodi has come, now for my current settup I have two issues I couldn't find an answer to.
1. After I adjust the screen (the actual border is outside of the screen) the screen setting keeps resetting when I start Kodi again? How can I fix this?
2. What are the best/correct audio settings in Kodi to take advantage of the xboxbx's Windows Sonic for Headphones or Dolby Atmos for Headphones. Currently I plug my Stereo Headphones into the Controller. In the Kodi Audio settings they show up as 5.1 Surroundsound device. But what number of channels do I have to chose 2.0 or 5.1. W
Will I get better sound with the stereo upmix option and what about if I put the resample quality to high?
Really appreciated if some of you could chime in!
https://forum.kodi.tv/showthread.php?tid=338035
They know about the screen resize issue, but no fix for the moment..
Can't help you with your audio question. Sorry.
Gr,
Johan
Okay, thanks for that..
I've got the same problem, I hope it will be fixed soon
For your audio question, I'm a user of Kodi and Dolby Atmos for Headphones too and I want to know if Kodi can use it. I will give a try tomorrow with the Dolby 7.1 test video, and see what's the best option. I'll tell you when It will be done. If you want to try by yourself, you can download the test video here https://mega.nz/#!xEBg3QID!Mi45xpLeDHhSF...HqaVze1CKI
