Full Version: Proper way to bring up the menu on Netflix 2 layout (maybe all layouts)
How do you bring up the menu configured in skin settings (the one that contains all your widgets)? I need to bring it up to get into settings but the only way I know is to highlight a widget cell with the mouse and then press left on the keyboard all the way to the left hand side of the widget then once more. Sometimes pressing back works but only sometimes I can't work out what to do to make back work. I'm using an Android box. Many thanks.
I found a hamburger menu icon appearing in the top right that if I click with the mouse brings up the menu but if I try and move the pointer to the menu it vanishes again.
It seems the best thing to do is highlight the hamburger with the mouse then press enter and use the keyboard to control the menu. Mouse support is quite wonky in Titan, it's a pity because it's the best skin.
