2019-01-22, 02:54
Pages: 1 2
2019-01-22, 03:11
Interesting. I'm curious how well it would work on the various streams. If it would help, I can capture a few minutes of live TV, both in raw MPEG2 format, and transcoded with the Extend.
2019-01-22, 18:46
I apologize. I'm not knowledgeable enough to understand the above.
2019-01-24, 03:48
No need for apologies. What I mean is, I can capture a few minutes of some local (to me) live TV into files that you can download and try playing on your Pi. If it would help you, that is. I imagine I can share them on Google drive.
2019-01-24, 18:10
Oh! Dear Me. This post is my way of my learning which (if any) HDHomeRun device to buy. FWIW, I had movies recorded in a variety of formats, MP4, M4V, maybe some other and my Pi/LibreELEC/Kodi stack plays them without problem. These movies were recorded using a SonicWorks HomeWorx PVR and then the harddrive they were recorded on was moved over to the Kodi stack.
2019-01-26, 05:21
I recorded 60 seconds of a local 1080i feed with no transcoding, plus heavy and mobile, and saved into files, which you should be able to access here: https://drive.google.com/open?id=1y5eSOw...keEpizNzcc
There were recorded with wget, e.g. for mobile: wget http://192.168.1.51:5004/auto/v5.1?durat...ode=mobile -O mobile.ts
2019-01-26, 07:09
All 3 played without flaw. No burping, sound sound. Perfect. But I don't understand what I've done. This means I want the Extend or I do want the Connect?
2019-01-26, 07:26
This shows that you can use the Connect. The Connect is not capable of transcoding, and would give you a stream like none.ts. You need to Extend to get streams like heavy.ts or mobile.ts (these are the names of the two highest-resolution transcode profiles of the Extend).
2019-01-26, 17:35
Thank you.
I would close this post if there were a way to do that.
2019-01-26, 18:11
I wouldn't worry about it. It will eventually roll down the thread list. In the meanwhile, I'll leave these video clips available for now, in case they might help someone else.
2019-01-26, 18:39
Allow me (Although we don't close threads, we just mark them).
Thread marked solved.
Pages: 1 2
