Full Version: Sonarr not updating Kodi
Sonarr send a signal to Kodi on media download and should prompt Kodi to update. I get the dialog notification about the download, but Kodi doesn't update.
No idea how to fix this. I suspect the issue is there are three separate systems involved, but can't figure out how to fix it.
- Kodi runs on a Fire Stick (192.168.1.38)
- Sonarr is setup on a server running Arch Linux (192.168.1.145)
- Sonarr downloads to a NAS drive with a NFS share where the media is stored (192.168.1.128)
- Kodi uses a mysql database (192.168.1.145)
- advancedsettings.xml has path substitution enabled so the database works
https://paste.kodi.tv/uqagimusit
debug log
https://paste.kodi.tv/mebakiziri.kodi
A Debug Log is the full log, not a snippet. I did see this though...
xml:
VideoInfoScanner: Finished scan. Scanning for video info took 00:00
This usually means your sources are not set up correctly.
Also, are you using the Sonarr NFO Files? If yes, then they are not compatible with Kodi.
Full Log if you want further assistance.
If you're getting the notification then it's connecting correctly so make sure you've enabled Update Library and Always Update in Sonarr.
My bad, here's the full debug log https://paste.kodi.tv/inapunuvor.kodi
