2019-01-20, 17:02
2019-01-20, 17:07
just figured out, sorry
sudo kodi start
sudo kodi start
2019-01-20, 18:36
Why would you need to be root to start kodi ??
2019-01-20, 18:47
so i am just testing.
I have kodi installed on raspbian and use it without screen to play internet radio. So far i control it via ios app Sybu. However i am trying, without success to make an autoexec.py to start kodi with a specitic internet stream. And while playing with the syntax i needed to restart to see if it works. Thats why. Actually what does not work is an autoexec.py
this is the script
import xbmc
xbmc.executebuiltin("Playmedia(http://s3.sonicabroadcast.com:8805)")
this is the script
import xbmc
2019-01-26, 23:06
@mina5000
One more time of URL spamming and you will be kicked of this forum instantly.
This is your first and final warning.
2021-08-22, 20:28
(2019-01-20, 17:07)VisiAndy Wrote: [ -> ]just figured out, sorry
sudo kodi start
Hi VisiAndy,
thank you for that command! Actually, following code lines work fine for me and my Raspberry (running Raspbian Buster).
sudo kodi start
sudo kodi stop
My only problem is that the command's action do not finish, means I do not get back to a new terminal command line.
I would like to start and stop Kodi with a Python script but the script gets stuck with the mentioned start command (same as in terminal).
I hope my question is not too “off topic”: Does somebody know how to avoid this behaviour or how to finish the start and stop action?
Thank you!
2021-08-22, 22:31
I use:
systemctl start kodi.service
systemctl stop kodi.service
on my install and command line comes back when its run.
2021-08-23, 01:21
(2021-08-22, 22:31)jeffski10 Wrote: [ -> ]I use:
Thank you for the fast reply jeffski10!
I was able to get
systemctl status kodi
● kodi.service - LSB: XBMC media centre
Loaded: loaded (/etc/init.d/kodi; generated)
Active: inactive (dead) since Mon 2021-08-23 00:06:44 BST; 1min 33s ago
Docs: man:systemd-sysv-generator(8)
Process: 411 ExecStart=/etc/init.d/kodi start (code=exited, status=0/SUCCESS)
Process: 1126 ExecStop=/etc/init.d/kodi stop (code=exited, status=0/SUCCESS)
Tasks: 34 (limit: 2059)
CGroup: /system.slice/kodi.service
├─553 /bin/sh /usr/bin/kodi --standalone
└─584 /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin_v7 --lircdev /var/ru
Do you have an idea what I have to do to get the stop command running? I am using Arctic: Zephyr 2 and it does not react to the command (at least command comes back in seconds... )
2021-08-23, 10:42
(2021-08-23, 01:21)Larry Add Wrote: [ -> ]Do you have an idea what I have to do to get the stop command running?
Mmm. Not sure as for me the stop command above works fine and stops the app but admittedly this is not on a pi. As you are on a pi and sounds like a native install rather than Libreelec assume you are using sudo as well ?
2021-08-23, 17:21
(2021-08-23, 10:42)jeffski10 Wrote: [ -> ]Correct I am using sudo to command... same effect.(2021-08-23, 01:21)Larry Add Wrote: [ -> ]Do you have an idea what I have to do to get the stop command running?
2021-08-23, 18:50
@Larry Add You need to be more explicit about what you want to do, what you are doing, what's your environment (OS, etc).
if you start Kodi with a desktop icon or DE menu systemctl command won't work.
There are many ways to skin the cat here, but it is absolutely unclear to me what you are trying to achieve.
sudo systemctl stop kodi
will work only if you start Kodi as a service with sudo systemctl start kodi
