Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
(2021-05-17, 10:01)Karellen Wrote: [ -> ]Do you have the Metadata Editor by @sualfred installed. If yes, then that is what is creating your NFO files. Disable it in the add-on's setting page
Yes! I do have that because I used it for manually editing a few personal file!!
Thanks, I'll disable it asap!
Addendum: I have just
disabled the scanning into the settings: it was enabled into the secondary profile for my wife!
Anybody else having problems with no artwork showing when scraping? Never had a problem before. I'm using Aeon Nox skin on an Odroid N2+
(2021-07-01, 12:36)smallclone Wrote: [ -> ]Anybody else having problems with no artwork showing when scraping? Never had a problem before. I'm using Aeon Nox skin on an Odroid N2+
Yes, same thing this morning: no artwork showing when scraping, just metadata. I, also, never encountered this problem before.
(2021-07-01, 13:13)zer0ner0 Wrote: [ -> ] (2021-07-01, 12:36)smallclone Wrote: [ -> ]Anybody else having problems with no artwork showing when scraping? Never had a problem before. I'm using Aeon Nox skin on an Odroid N2+
OSMC Vero 4K+.
+1
Same for me since this morning, yesterday i have no issues when i scrape a movie.
Btw, if i edit my db and added manually the address of the image from TMDB, it works.
You can also use the kodi webui on your browser and through more/edit find the online poster/ background but this is a workaround not a solution.
(2021-07-01, 16:50)zer0ner0 Wrote: [ -> ]You can also use the kodi webui on your browser and through more/edit find the online poster/ background but this is a workaround not a solution.
That's what i do, it works when you add TMDB address for the image. Not really the solution but for the moment, it's all i have found.
Please provide a
Debug Log that captures the issue. Also links to the movies that have this issue
No artwork here also. If i scrape with The Movie Database Python i get artwork. The Movie Database and Universal Movie Scraper i get nothing.
This goes for all the movies i have tried so far.
Matrix 19.1
posted a couple of hours ago by a tmdb staff member
https://www.themoviedb.org/talk/60de0392...0074955f5d
Quote:Hey everyone,
I don't think we're filtering images properly with ?include_image_language=null at the moment. Looks like a bug slipped in. Given today is a holiday in Canada, and I'm busy for a bit, I won't be able to look at this until later tonight. I will update this post once I have deployed the fix.
Cheers.
Thanks, so if i understand correctly, it's on the side of the API and not user's side ?
Tested here on 2 different Kodi, the bug is still present, no images when scraping.
