Full Version: Rapier 11.2.26 Update
I have been trying, unsuccessfully to update Rapier from 11.1.11 to 11.2.26 for sometime. I have installed Kodi Leia RC5 but still no luck. This is on a Windows PC media center. It appears to download and the install starts but always stops at exactly 70%. I thought it might be a dependency issue but they all appear to be installed. Every time I restart Kodi Rapier shows as an available update but the same “failed to install” appears. Any suggestions would be appreciated.
Tom
Windows 10
Kodi 18RC5
Rapier 11.1.11
Hi this is a Kodi core problem which have been fixed in next nightlys Smile
https://github.com/xbmc/xbmc/milestone/117
so it will be fixed with kodi 18.
work arround for you now:
switch to estuary skin, restart kodi, make the update and switch back to rapier.
Thanks Skybird, the workaround did the trick. Hope this get’s resolved in the final 18 release.
Great, I'll mark this thread as solved, as it's not a skin issue.
