Full Version: Where is the play mode/repeat toggle in the official iOS remote
I noticed that any file seems to play over and over indefinitely.  Where is the option to disable repeat mode in the official iOS remote?
EDIT: I was able to fix this using kodi-send -a "PlayerControl(RepeatOff)" from the shell while a video was playing but seems like there should be a way to easily see the playback mode and toggle it from within the app.
tap on the cover art into the now playing view and you'll find the options you are looking for in the bottom
@joethefox - Thanks very much... I see it now.  Tough to find Wink
you're welcome! yes, I usually tap on everywhere when I use new apps  Big Grin
