2019-01-27, 01:07
Updated August 18, 2019
All I can say is grab this remote ASAP for just $14.99 (50% off regular price, probably not for long). It's a steal! (Not on sale anymore, but still a good buy)
All buttons, except for the Voice button, will work! I tested with both LibreELEC (an AMLogic S905X box) and CoreELEC (a S912 box). This remote will likely work with Raspberry Pi and Chromeboxes running LE as well if they have Bluetooth capability. Also works well with nVidia Shield & Mi Box (tested with both), and I'd expect w/Mi Box-es and some other Android boxes with Bluetooth. I bought 3 of them for all my other Kodi boxes .
My Amazon remote set-up with a S912 box & Odroid N2 (S922X), both w/CoreELEC installed:
Requirements to get the most out of this remote:
Steps:
Assuming you want volume controls, first pair your new FTV remote with compatible FTV device (listed above). To do this, use your original (already paired) FTV remote to go to Settings > Controllers & Bluetooth Devices...
Next up is setting up Equipment Control. As I had already done this with my Fire TV Stick 4K, the new Amazon remote also picked up my AVR's volume up/down and mute functionality. The Power button can be set-up with Equipment Control to power on/off your FTV device, AVR or soundbar and your TV. Unfortunately, it doesn't work with projectors (what I use), so my Power button turns on/off my AVR. So, keep in mind that whatever is/was programmed w/the Power button carries over after you pair with Kodi (CoreELEC or LibreELEC). In my case, I used Keymap Editor to have the Power button Reboot Kodi, and it worked, but it also turned off my AVR. A good way to detach the Power button's functionality from Amazon's Equipment Control was discovered by @axbmcuser later in this post (thanks for the nifty trick). If you haven't already set-up Equipment Control, and want volume control in Kodi, you should do so now...
Now, here are the final steps, to pair the new Amazon remote with Kodi. Before doing this, I'd suggest unplugging your Fire TV device (that the new remote is now paired to) so there isn't any interference. Let me show steps I used with a S912 box w/CoreELEC...
If pairing doesn't work with CoreELEC, keep trying (after deleting the AR bluebooth entry). After putting Amazon remote in pairing mode, and choosing AR, choose 'Trust and Connect' first, immediately followed by 'Pair'.
Things that make the new Amazon remote great are:
- Very responsive w/CE or LE
- Volume control for AVR or TV
- Solid buid quality, easy to hold, use
- 15 (out of the 16) buttons are usable, mappable
- Doesn't lose Bluetooth connection/pairing
- Cheap
- A compatible Fire TV device (Stick 2nd gen, Stick 4K, Pendant or Cube) and the FTV remote that's already paired w/it (If you don't care for volume controls, then skip)
- Kodi program add-on Keymap Editor (from the official repository)
Steps:
- Cheap
