ATTENTION ALL REGIONS SUPPORTED BY THIS ADD-ON SWITCHED TO HBO MAX, A HBO MAX ADD-ON ALREADY EXIST HERE: 358484 (thread).
Disclaimer
This add-on is not officially commissioned/supported by HBO®. The trademark HBO® Go is registered by Home Box Office, Inc.
For more information on HBO® Go visit the official HBO® Go website for your region.
I do not own any of the content this add-on lists. The content belongs to Home Box Office, Inc.
All this add-on does is make simple HTTP requests to Hbo go servers to retrieve and display content just like any web browser would do!
Important: HBO® Go must be paid for!!! You need a valid HBO® Go account for the add-on to work! Register on the official HBO® Go website for your region
THERE IS NO WARRANTY FOR THE ADD-ON, IT MIGHT NOT WORK AT ALL AND IT CAN BREAK AND STOP WORKING AT ANY TIME.
If an official app is available for your platform, use it instead of this.
hGO EU, inputstream.adaptive based HBO GO Add-on for Kodi
[plugin.video.hbogoeu]
PLEASE IF YOU ARE REPORTING AN ISSUE PROVIDE Full uncut Kodi Debug Logs.
Without a full log is difficult or impossible to guess what's going on.
Also, read and keep in line with Forum Rules, no support will be given here if your device is contaminated by Banned Add-ons.
Current HBO Go add-on regions support FULL SUPPORTED OPERATOR LIST
HBO REGIONS (API-s) / Feature |
Europe |
Nordic+Spain | USA |
Latin America |
Asia |
Basic functions |
YES |
YES |
NO |
NO |
NO |
Search |
YES |
YES |
NO |
NO |
NO |
5.1 Audio |
N/A |
YES |
NO |
NO |
NO |
Subtitles |
YES |
YES |
NO |
NO |
NO |
My List |
YES |
YES |
NO |
NO |
NO |
Add/Remove from My List |
YES |
YES |
NO |
NO |
NO |
Voting |
YES |
N/A |
NO |
NO |
NO |
Report/Get play status to HBO |
YES |
NO |
NO |
NO |
NO |
Legend:
YES - feature availible for the region and working in the add-on,
NO - feature availible for the region but not implemented or broken in the add-on,
N/A - feature not availible for the region,
TEST - feature implemented in test version
This add-on currently covers
18 countries:
FULL LIST OF SUPPORTED COUNTRIES/OPERATORS
Install instructions- Works on Kodi 18 (Leia) or later
- A valid HBO® Go account is needed for the add-on to work
- Simply install from the Kodi add-on repository (search hgo or hbo to find quickly or browse under the video category)
- Follow the setup wizard at first add-on run
- The add-on should install the inputstreamhelper add-on which will help with inputstream.adaptive and DRM setup if needed
- OPTIONAL: Configure additional preferences in the add-on config
Manual install from zip:
Latest stable release
Change log
changelog.md
Source
https://github.com/arvvoid/plugin.video.hbogoeu
Are you going to support more countries? I'm from Spain and I do not see it on the list.
I included all countries listed on
http://hbogo.eu spain is not listed there
As they add more or i discover a new one i will add it if possible.
Is this the correct website for Spain
https://en.hboespana.com/ ? is partially blocked from here only login allowed
It seems it uses a different API will look into it in more details in the next few days
If there are more countries where hbo go is available, missing from the list please report it and I will see what I can do
(2019-01-27, 18:01)arvvoid Wrote: [ -> ]Is this the correct website for Spain https://en.hboespana.com/ ? is partially blocked from here only login allowed
Yes, that's the right HBO site in Spain. Thank you, waiting for news from you ...
I found some information:
Quote:In Europe, HBO now operates the three regional OTT platforms HBO España, HBO Nordic (Sweden, Denmark, Norway and Finland), and HBO Go in 12 Central European countries.
So HBO Go in 12 Central European countries is
http://hbogo.eu and that is covered by this add-on, they all share the same api and just have a list of diferent provider ids for each country. So when they add something to hbogo.eu is just a matter of including those ids in this add-on.
HBO España (
https://en.hboespana.com/), HBO Nordic (
https://www.hbonordic.com/) are structured differently and use a different api from what i see, but the 2 have the same api just different api urls. To include them the api have to be figured out first and that would require a collaboration with someone local that has a valid account to those services.
Once the api is figured out implementing it is not a problem.
HBO Go US (
http://hbogo.com) (completely blocked from here didn't check, probably have it's own api and structure, or might share the same one with HBO España and HBO Nordic but that's a guess)
HBO Go Asia (
https://www.hbogoasia.com/) ( completely blocked from here didn't check)
HBO Go Latin America (
https://www.hbogo.com.br/) ( completely blocked from here didn't check)
Hi .
I instaled last night Hbo Go EU plugin and after i introduced the username and pasw and tryed to run a movie i get an error like " Check the username/email and pasword " and " general error " messages .
I have a valid account on UPC ROmania and i use HBOGO on smart phone so my username and pasw are valid
I use it on Raspberry PI 3 with LibreELEC (Leia) v8.95.3 BETA .
How can i fix this error .
Thank's
(2019-01-28, 10:26)fireangel Wrote: [ -> ]Hi .
Thank's
Hello thanks for testing the add-on out,
please provide a debug log so i can figure out what's going on:
https://kodi.wiki/view/Log_file/Easy
In the meantime make sure you selected "Romania: UPC Romania" in the addon settings (Restart LibreELEC just to be sure, and try again). Also, try to login in
https://hbogo.ro just to double check the inputed credentials.
(2019-01-28, 11:07)arvvoid Wrote: [ -> ] (2019-01-28, 10:26)fireangel Wrote: [ -> ]Hi .
Thank's
please provide a debug log so i can figure out what's going on: https://kodi.wiki/view/Log_file/Easy
In the meantime make sure you selected "Romania: UPC Romania" in the addon settings (Restart LibreELEC just to be sure, and try again). Also, try to login in https://hbogo.ro just to double check the inputed credentials.
Figured out what is going on. When UPC Romania get select as operator on the hbogo.ro website you get redirected on the UPC Romania web site and have to login there instead of logging in directly on the hbogo website like most other operators.
For a few other operators it works that way as well:
Czech Republic: Skylink [REDIRECT LOGIN]
Czech Republic: UPC CZ [REDIRECT LOGIN]
Polonia: Cyfrowy Polsat [REDIRECT LOGIN]
Romania: Telekom Romania [REDIRECT LOGIN]
Romania: UPC Romania [REDIRECT LOGIN]
Romania: Vodafone Romania 4GTV+ [REDIRECT LOGIN]
Slovakia: Skylink [REDIRECT LOGIN]
Slovakia: UPC CZ [REDIRECT LOGIN]
That login method is not expected and not implemented in the add-on so those operators will most likely all fail to login.
All other operators should be fine and work as expected.
Further discussion about the issue and updates about the issue:
ISSUE #5A debug log with the latest version:
plugin.video.hbogoeu-2.0.2.EU.BETA.zip would still help.
Info updated on
https://github.com/arvvoid/plugin.video.hbogoeu/
PS For a moderator/admin passing by: I would like if possible to update the info on my initial post but can't edit my posts, missing the permission to do so.
Hi
i was waiting for this pluginn for a long time, I have an HBO GO Latin america account, I would like to help you test the plugin
(2019-01-28, 10:26)arvvoid Wrote: [ -> ][font][font]He encontrado alguna información:[/font][/font]
Quote:[font][font]En Europa, HBO ahora opera las tres plataformas regionales OTT HBO España, HBO Nordic (Suecia, Dinamarca, Noruega y Finlandia) y HBO Go en 12 países de Europa Central.[/font][/font]
[font][font]Entonces, HBO Go en 12 países de Europa Central es http://hbogo.eu y está cubierto por este complemento, todos comparten la misma API y solo tienen una lista de diferentes ID de proveedores para cada país. [/font][font]Entonces, cuando agregan algo a hbogo.eu es solo cuestión de incluir esos ID en este complemento. [/font][/font]
[font][font]HBO España (https://en.hboespana.com/), HBO Nordic (https://www.hbonordic.com/) están estructurados de manera diferente y utilizan una api diferente a la que veo, pero las 2 tienen la misma api diferentes URLs de la API. [/font][font]Para incluirlos, primero se debe averiguar la API y eso requeriría una colaboración con alguien local que tenga una cuenta válida para esos servicios. [/font][/font]
[font][font]Una vez que el api está resuelto, la implementación no es un problema.[/font][/font]
[font][font]HBO Go US (http://hbogo.com) (completamente bloqueado desde aquí no lo [/font][/font]
If I can help in some way for HBO Spain, count on me[font][font], probablemente tenga su propia API y estructura, o podría compartir el mismo con HBO España y HBO Nordic, pero eso es una suposición) [/font][/font]
[font][font]HBO Go Asia (https://www.hbogoasia.com/) (completamente bloqueado desde aquí no se verificó) [/font][/font]
[font][font]HBO Go Latin America (https://www.hbogo.com.br/) (completamente bloqueado desde aquí no se verificó)[/font][/font]
Thanks for quick update, I will test and I let you known if work or not.
If you still need the log file, its here :
https://paste.kodi.tv/xorofopabo
I hope I do it right
Thanks again...
Sorry for double post , i did by mistake .
Btw , its help if i give you my account details on hbo go for testing ?
For the HBO Nordic API you might get some help by looking at this
addon
Thanks again...
The fix is still a work in progress, but at least I know what operators are affected and why. Thanks for reporting.
Quote:Posted by farid77 - Yesterday, 17:03
Hi
Thanks but this add-on have no support for HBO GO Lantin America which use a different API and is blocked from here. At the moment i don't plan working on that.
Quote:Posted by macardi - 3 hours ago
For the HBO Nordic API you might get some help by looking at this addon
Looks like a launcher add-on from a quick look (launches and controls hbo go in a browser via external program), that won't help implementing it here. Will take a look in more detail when I catch a little time. Thanks for sharing.
Thanks, but at the moment can't work on that for lack of time, maybe in the future if someone doesn't do it before.
